It is currently Fri Aug 22, 2025 6:58 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jun 22, 2013 2:40 am
First name: Lee
Last Name: Passmoor
City: Newport Pagnell
State: Bucks
Zip/Postal Code: MK16 8JG
Country: United Kingdom
Colin North wrote:
Undersized Frisket film, 1 thou, matt, extra tack was recommended in a thread here on OLF.
I tried it on my last finish, and after a few coats the thickness just disappeared as I sanded/levelled/buffed, but the matt of the film could still be seen making removal a breeze.
I'm a convert. bliss
Hi Colin,
Where do you get your extra tack film from in the UK?
PostPosted: Sat Jun 22, 2013 10:40 am
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Hi Wes,
I actually put two layers of tape down on a cutting mat, lay the bridge on top and cut out the shape with an exacto knife. I'm not cutting any smaller. But I do occasionally have a little clean up to do with an exacto knife and chisel when done. I've been using this approach for the last several years with no issues.
After spraying finish, I simply remove the top layer of tape. Final film thickness prior to final leveling and buffing can also be done by throwing a caliper on the top layer of tape:
This leaves a slight ridge at the seam, which can now easily be leveled and buffed without worry of contaminating the spruce underneath:
All buffed out:
A little scraping with a razor blade, some clean up, and ready for the bridge:
Bridge is on and fits neatly in the masked area:
As you have seen, lots of ways to go about it, but this approach for me is very simple and has worked well. The trickiest part is cutting the mask. I always cut the mask and locate it on the guitar, then I double check by placing the bridge on the mask to make sure I haven't stretched the tape. It's pretty easy to remove lacquer, a little hard to add if the mask has been cut too large.
weslewis wrote:
Ken are you masking slightly smaller than the bridge????
http://www.casperguitar.com
PostPosted: Sat Jun 22, 2013 10:56 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Actually on my last one I used frisquit
MK5acoustics.com
PostPosted: Sat Jun 22, 2013 11:00 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Oops I used the 001 and cut to the exact size then after finishing I lightly scored around the bridge and fit perfect, however I thought I might have gotten lucky so I thought I would see what others are doing your method seems pretty solid
MK5acoustics.com
PostPosted: Sat Jun 22, 2013 6:29 pm
Hi Colin,
Got pretty much a lifetimes supply from http://www.ebay.co.uk/itm/Grafix-Extra-Tack-Frisket-Film-Roll-12-Inch-by-4-Yards-Matte-/111091406515?pt=UK_Crafts_Other_Crafts_EH&hash=item19dd9056b3
Only source I could find at the time.
